How Old is my South Bend Lathe?
Although South Bend retain comprehensive records of their lathe production (and can quote an exact dispatch date for almost every machine ever made) it is possible, thanks to the efforts of Geoff Swayze, to calculate an approximate date of manufacture. The error appears to be only plus or minus one year or so and, if you enter the serial number (stamped at the tailstock-end of the bed), raise it to the power of 0.0059 and then multiplied by 1812 a result should be obtained.
The procedure is as follows:
On a scientific calculator (the one with any version of Windows will suffice) enter the serial number, say 84243; then hit the X^Y key (X with a superscript Y); type in 0.0059 then hit the "=" key followed by the multiplication key (*) followed by 1812. You should obtain 1937.4 which is within one year of the real date of manufacture, 1938.
Until a change of policy in 1947 - and a production total of approximately 186,500 lathes  - South Bend used a simple sequential numbering system, but after that Serials were broken down between different types of lathe with numbers assigned sequentially within a group.  Adding the highest number seen in each category post-1947 to pre-1947, gives a total production of just a over 330,000; however, by the 1970s, South Bend's range was very limited and most of the lathes produced during the last 30 years of the 20th century were the eternally-popular model 10K - a direct descendent of the original 9-inch lathe of the 1030s.
On many South Bend lathes, especially those built before the early 1920s, while the serial number is stamped into the end of the bed at the tailstock end, numbers are also stamped into many other parts - sometimes, but not necessarily, the last three digits of the serial number. These would have been used to identify components taken off an initially assembled lathe for final finishing or painting. Such items might have been
the top of the leadscrew hanger bearing bracket, the changewheel bracket, the leadscrew, on the concealed surface of the rack where it abuts against the bed and on the inside of the apron, etc..
South Bend Catalogs Complete Editions 1918 to 1967
South Bend Lathes pre-1920  South Bend Lathes 1920-30
South Bend Model 5 - Earliest of the 9-inch "Workshop" Lathes
First Ever Model 5 Catalog - the original "mention" of the 9-inch
South Bend 9-inch "Workshop" Lathe  South Bend 9-inch Catalogs
South Bend Lathe Accessories
8-inch & 9-inch Junior & Model R   8-inch and 9-inch Junior Lathes Photographic Essays
Historic, very early 1910 South Bend 10-inch  Series 20 Toolroom Lathe - Superbly Restored
South Bend Heavy Ten - an overview   South Bend Heavy 10 from 1961 and 1991 Models
South Bend Heavy Ten Specification Catalogs   South Bend 10-K Light Ten
South Bend G-26-T   South Bend Silent-chain Drive Lathes
South Bend Lifted-Centre-Height Lathes
Copies and Clones of South Bend Lathes:
Boxford, Ace, Blomqvist, Smart & Brown, Purcell, Sheraton, Hercus, Sanches Blanes
Special Factory Production Machines   South Bend Factory   Making the South Bend
South Bend Users' Group
How old is my South Bend Lathe?
The Rarest South Bend Lathe
South Bend Shapers
Rebuilding a 1952 South Bend 13-inch (large PDF)
