South Bend Lathe Silent-chain Drive
South Bend 1941 Catalog Complete
South Bend Catalogs Complete Editions 1918 to 1967
South Bend Lathes pre-1920  South Bend Lathes 1920-30
South Bend Model 5 - Earliest of the 9-inch "Workshop" Lathes
First Ever Model 5 Catalog - the original "mention" of the 9-inch
South Bend 9-inch "Workshop" Lathe  South Bend 9-inch Catalogs
South Bend Lathe Accessories
8-inch & 9-inch Junior & Model R   8-inch and 9-inch Junior Lathes Photographic Essays
Historic, very early 1910 South Bend 10-inch  Series 20 Toolroom Lathe - Superbly Restored
South Bend Heavy Ten - an overview   South Bend Heavy 10 from 1961 and 1991 Models
South Bend Heavy Ten Specification Catalogs   South Bend 10-K Light Ten
South Bend G-26-T   South Bend Silent-chain Drive Lathes
South Bend Lifted-Centre-Height Lathes
Copies and Clones of South Bend Lathes:
Boxford, Ace, Blomqvist, Smart & Brown, Purcell, Sheraton, Hercus, Sanches Blanes
Special Factory Production Machines   South Bend Factory   Making the South Bend
South Bend Users' Group   How old is my South Bend Lathe? The Rarest South Bend Lathe
South Bend Shapers    Rebuilding a 1952 South Bend 13-inch (large PDF)
1918 South Bend "Silent Chain Motor Driven Lathe"
Until the 1920s, and in some cases for very much longer, most machine shops had what would today be called an "Integrated Power System". At the heart of the system was a lovingly-cared-for large steam engine or electric motor that drove, via a convoluted run of belts and ropes through a labyrinthine maze of pulleys hanging from bearings attached to girder work inside the roof of the building, each of the factory's machine tools. The drive assembly in the roof was referred to as 'line shafting'.
Each machine was attached to the overhead shafting by a wide, flat belt, usually with some sort of ancillary control system which involved "fast-and-loose pulleys" where a belt, idling on a "loose" or free pulley could be flicked across to a "fast" or connected pulley which, being fastened to (or part of) another pulley next to it, provided drive to a machine on the floor below. Other more complex systems were also used that involved such intricacies as bevel-gear drives, built in split-ring clutches, foot-operated belt throwers and automatic lubrication systems. Once an overhead drive system had been expensively installed in a specially-prepared building, the nightmare of maintaining and constantly overhauling the multitude of bushings and hangers, inconveniently and dangerously located ten or twenty feet in the air, could begin. No wonder Works Engineers clocked-off dreaming of a better solution; their salvation eventfully came in the form of the small, high-speed electric motor that was able to provide each machine with its own, independent, power source. The tricky installation of a drive system could be delegated to the machine maker and now, if you fell out with your landlord, it was possible to pull the machine tools out of their Victorian dungeon and move across the road, or town, to somewhere both more convivial and cheaper - to say nothing of enjoying the other advantages that individually powered machines brought to the workshop and production process,.
South Bend were early in the market with a self-contained drive system, although at first it was only offered as a very expensive extra that added over 50% to the cost of the smallest machine and 27% to the largest - plus the cost of the motor itself..
The claims for the "Silent Chain" drive system were impressive. South Bend maintained that the lathe, installed in an office, would run so silently that the occupants of the next room would not hear it run - even if  they would, in reality, have certainly heard and smelt it working.
The countershaft was mounted on oil-immersed, self-aligning roller bearings and provided with an over-centre tensioning device which, maintained the makers, allowed the belt tension to be released and the belt moved from pulley to pulley whilst the lathe was running - not an action likely to calm the countenance of today's safety inspector from the Nanny State.. The motor speed was recommended to be 900 rpm and a reversing switch was provided  complete with a long operating bar which stretched the full length of the lathe bed; the attachment of this extension to the switch can be seen in the photograph above.
By 1933, with lathe production having topped 55,000, the same system was still in production, mounted in an identical manner above the headstock of the lathe but with the massive (and expensive) inverted-tooth chain  having been replaced by a conventional V belt - and the system naturally renamed the "Silent V-Belt Drive"..
