Early and later Pratt & Whitney compound slide rests. That on the left is from a 3c and on the right from the older No. 3. While both follow the same basic design, that used on the 3C has a slightly longer travel on the top slide, and usefully more on the cross. Other refinements include a better oiling system, larger micrometer dials, ball bearings thrust races and travel stops for the cross movement
