LORCH Precision Screwcutting Lathe
Types BL27LZ
Lorch Home Page
and well-illustrated Sales & Technical Specification Brochures and can be purchased on-line here
The often worn Lorch Lathes top-slide screws and nuts can be
made to order. Phone 01298-871633 or email: tony@lathes.co.uk
With a centre height of 4.74" the BL27LZ was (alongside the variable-speed B30LZS),  the largest of the Lorch precision lathes as first produced from the 1950s - and the only one to include a full screwcutting gearbox and power sliding and surfacing. Although it was based on the plain-turning lathes in the range - it was a different machine in almost all respects.
Very heavily constructed, with diagonal bracing webs and cast from a special grade of  iron which was claimed to be wear resistant, the bed had ways consisting of twin Vees and flats. Just one length was offered, admitting 22" between centres, with the machine mounted on a vibration-absorbing , heavy cast-iron cabinet base containing a 3-phase motor with three speeds of 700, 1400 and 2800 rpm. (a welded sheet steel cabinet was optional). The drive from the motor passed to a two-step pulley that drove directly upwards to the headstock by a smooth-running, endless flat belt; combined with the single-lever engaged backgear this arrangement produced 12 spindle speeds from 47 to 2100 rpm.
The leadscrew, enclosed within the bed in a manner not dissimilar to that used on the  Schaublin 102VM, was completely protected from swarf and dirt.
Hardened, ground and "Superfinished", the stout No. 4 Morse taper headstock spindle ran in an adjustable plain bearing at the front and an angular-contact (ball) bearing at the rear.
Using hardened and ground gears running in an oil bath, the headstock backgear assembly was controlled by the action of just one lever - there being no pins, nuts or other retainers to undo or slacken before it could be engaged - a single movement simultaneously disengaged the bull wheel from then pulley and brought the gears into mesh. The spindle accepted draw-in collets of 27 mm diameter, with a maximum through capacity of 13/16" - and a non-through  of 29/32".
Able to generate 34 metric and 25 English pitches - and with the substitution of one gear 24 module pitches as well - the screwcutting gearbox also produced sliding feeds that varied between 0.0007" and 0.024" per rev - and surfacing feeds from 0.00035" to 0.012" per rev. Besides a gear drive for screwcutting, the box was also fitted with a very fine-feed drive by V-belts for the power sliding and surfacing .
Double-walled, the apron had the expected safety interlocking between power sliding and surfacing feeds to prevent their simultaneous engagement - and consequent mechanical mayhem. Both power feeds could be disengaged by a most useful, pre-set micrometer-adjustable stop - or automatically if overloaded.
The BL27LZ (and B30LZS) were expensive lathes, bought only by the most knowledgeable of toolroom supervisors - and remains to this day most sought-after and elusive machines..
NOTE: Lorch lathes were advertised using Roman numerals - but are also found stamped using decimal notation e.g. the AV1-K might be found stamped  A 6 K and the AV11-K as A 7 K
Larger lathes branded Lorch, Schmidt & Co.
LAS Precision Screwcutting and LAS, AV1-K, AV11-K, LLRGN,  AVRG, BVIRG, LLRN, AVR  &  BVIR Lathes
Lorch LAS Photographic Essay
Sliding Headstock Screwcutting BVIPK
Lorch LL "tall-feet" Clockmakers' Lathe
Precision Plain Lathes: LLS, LLV,LLK
Precision 50 mm Lorch KD50
Toolmakers' Screwcutting Lathe AVI-L
Screwcutting Type AB     Precision Screwcutting Lathe BL27LZ
Precision Screwcutting Lathe B30LZS
Toolmakers' Miniature Lathes: LA, LAN, LLN & LLPN Plain and Screwcutting with Leadscrew
Lorch lathes--Newer Accessories
Lorch lathes--Older Accessories
Larger Screwcutting Lathes D27 & BIIZ
Lorch Dividing Apparatus for Watchmakers' Lathes
Lorch COLLETS
Lorch Watchmakers' Lathes
Lorch "Triumph" Watchmakers' Lathe
Lorch Junior Watchmaker's Lathe
Lorch Lathe Restoration   Lorch Lathe Restoration - 2
Early Lorch Model A Lathes - circa 1885 to 1920
Lorch Milling Machines
Lorch Manufacturing Programme Circa 1950
