Books   Accessories
Unimat Copy - Origin Unknown
Unimat Home Page  Emco Home Page  Accessories  Earliest Unimat - Photographs Page 1 and Page 2
Home-made Unimat No.1   Home-made Unimat No.2   ROWIC - Argentinean Collets  Mk. 4 Photographs
Display Cabinet With Every Known Accessory   Boxed unused SL1000 & DB200
Early German Unimat Catalogue
Instruction Books, Parts Books and drive
belts are available for the DB200 & SL1000
Although superficially similar to the Russian-built copy this example is obviously from a different maker, and possibly East German in origin. Whilst the machine lacked an integral metal baseplate, and bed bars appears hopelessly light in comparison with the original, the headstock appears to have been robust enough and the cross-slide travel obviously greater. It appears that all the micrometer dials could be zeroed. Like the Emco, the headstock could be removed and fastened to a vertical milling and drilling column. However, this was a very much more complicated affair than the simple plain bar used on the SL1000/DB200 with the head-carrying bracket driven up and down by a screw-feed and guided by a proper, full-length alignment key. A micrometer feed-dial was fitted at the top and what looks to have been an adjustable rotation-dial at the base.
If you have details of this lathe the writer would be pleased to hear from you.
Other unusual versions of the Unimat here and here..
The drive bracket was arranged to carry pulleys giving both high and low speed
Like the Emco the headstock could be removed and fastened to a vertical milling and drilling column. However, this was a very much more complicated affair than the simple plain bar used on the SL1000/DB200 with the head-carrying bracket driven up and down by a screw-feed and guided by a proper, full-length alignment key. A micrometer feed-dial was fitted at the top and what looks like an adjustable rotation-dial at the base.
Russian Copy  Nameplates  Unknown  Motors  Motor Repair  Computer Control
Home-made SL1000  ROWIC - Argentinean Collets  Mk. 4 Photographs
Books   Accessories
