Although INDEX always bought suitable standard machine-tools from other makers when a special-purpose machine was required, they could always build their own - as this complex production milling machine demonstrates
Gear Grinding on a Reishauer machine
As Index automatic lathes were expected to perform to the highest standards over many years of hard work, many parts were hardened and ground. This is one of the hardening shops, equipped with a gas carburizing plant
High-frequency induction hardening
An early example of an INDEX automatic. Notice the exposed cams on the front shaft and the use of manual lever feeds. More on these interesting lathes to follow. However, if you have hands-on experience of using one the writer would be pleased to hear from you.
