E-Mail Tony@lathes.co.uk Home Machine Tool Archive Machine Tools For Sale & Wanted Machine Tool Manuals Catalogues Belts Books Accessories
Bradford Lathes 14-inch Stud or Bolt Lathes Bradford Home Page 14-inch Stud Lathes 16 & 18-inch Lathes 21, 25 & 28-inch Lathes 30, 32, 36 & 42-inch Lathes Carriage & Slides Accessories Factory Headstock, Bearings & Friction Backgear 1940s & 1950s Metalmaster Coarse Screwcutting Attachment
A Maker's Instruction Book, Parts List, Sectional-diagram Books and catalogs are available for Bradford lathes
The "Stud" lathe was designed as a simple machine, shorn of unnecessary features, and intended for the rapid production of screwed studs and bolts. The apron was of the expensive "rise-and-fall" type, which allowed rapid and accurate setting of the tool height - though doing nothing for rigidity and turning performance, which hardly mattered on this type of small-diameter work. The compound slide rest was omitted, as was power cross feed - both being incompatible with the special type of saddle used.
14-inch Stud lathe, without backgear and screwcutting but with a belt-driven powershaft for power sliding feed.
Special "rise-and-fall" apron with single tool slide. The whole of the cross-slide assembly was pivoted along its front edge, with the elevating control by a screw thread at the back.
14-inch stud lathe with backgear.
