Early saddle and apron assembly
Saddle and apron cast as-one
Late-type apron with adjustable carriage handwheel
Component parts of the top slide
Component parts of the tailstock. Note (bottom right) the proper split compression clamp to lock the spindle
Late-model Atlas/Craftsman 6-inch Mk. 2 headstock cast in ZAMAK. Note the thin walls and generally weak appearance of the assembly with the all-important spindle bearing housing being of particularly flimsy construction
Outside of a ZAMAK headstock casting
Note only was the original cast-iron headstock casting in a stronger material, it was also much more heavily constructed. Note the mass of metal supporting the spindle bearings
