Screwcutting Lathe Model 00 "> Page Title
Ames of Chicopee Mass. - Page 4
Parts - a Photographic Essay Continued
If any reader has an Ames of Chicopee lathe, and would like to supply a set of
pictures for use in the Archive, the writer would be delighted to make contact
Ames of Chicopee Mass. Home Page   Ames of Chicopee Page 2   Ames of Chicopee Parts - Page 3
The "other" Ames Home Page
Leadscrew hanger bearing
Leadscrew hanger bearing - component parts including the leather thrust washer
Tumble-reverse mechanism
Tumble-reverse gears - with evidence of past impatience...
"Balanced" handle with cross-feed screw
Cross-feed screw component parts
The unusually complex changewheel bracket - component parts
The unusually complex changewheel bracket assembled - note the slotted-head screw stamped with an assembly number
Another view of the assembled changewheel bracket
Square spindle from the tailstock and its feed screw
An unusual circa 1870 4-jaw self-centering drill chuck of about 3/8 capacity and most unusual construction: the No.1 Morse taper shank - machined with a keyway along its parallel section - is screwed, using what appears to be an Acme thread, into the inner body of the chuck. Inside the chuck a pin engages a hole through the end of the thread - but apparently missing is a knurled knob of some kind that would have been secured to the shank and used the keyway to tighten the jaws
A contemporary 3-jaw chuck by D. E. Winton mounted on a new backplate with the correct, square-head retaining bolts
Ames of Chicopee Mass. Home Page   Ames of Chicopee Page 2   Ames of Chicopee Parts Page 3
