Screwcutting Lathe Model 00 "> Ames of Chicopee Page 3
Ames of Chicopee Mass. - Page 3
Parts - a Photographic Essay - continued on Page 4
If any reader has an Ames of Chicopee lathe, and would like to supply a set of
pictures for use in the Archive, the writer would be delighted to make contact
Chicopee Home Page   Chicopee Page 2   Chicopee Page 4
The "other" Ames Home Page
The complete Ames Chicopee headstock spindle, bearings and backgear assembly
Headstock spindle end with its 13/16" x 12 t.p.i. thread and, usefully, a hole drilled the inner boss that allowed a bar to be inserted and the spindle locked for the removal of fittings
Careful cleaning has revealed the remains of the original colour and pin striping
Note the carriage-drive rack machined directly into the bed instead of being bolted on
Evidence that machining the bed involved the use of a planer - the tool marks are clearly visible
Waste not, want not: inserted bronze pads used to recover a flawed the carriage handwheel
Carriage traverse handwheel cover from the apron that contained a set of reduction gears to give a fine and steady feed to the hand feed (a system that was very unusual at the time when a quick-action, awkward-to-use crank handle would have been expected). The cover, instead of being a simple, prosaic affair was made from a casting of the very finest grain and appeared to have been either gun blued or treated to some contemporary "slow-to-rust" finish.
Note the number stampings to ensure that the "made in the factory" screws went back into the right place
The almost unworn  bronze leadscrew clasp nuts
Photographic Essay Continued on Page 4
Ames of Chicopee Mass. Home Page   Ames of Chicopee Page 2
