George Adams of London
Watchmakers' Lathes - Page 2
Watchmakers' Lathes Home   Watchmakers' Lathes Page 3
Watchmakers' Lathes Photographs
George Adams Home Page   GA Lathe Model 21/2
G.A. Watchmakers' Lathes     G.A. Round Bed Lathe
3.25" & 4.75" Screwcutting Lathes Models D, E, F, G & H
4" & 5.25" 4" & 5.25" Screwcutting Models A, B, L, KF1 and CL
3.25" & 4.75" Precision Lathes Models D, E, F, G & H
2.75" Screwcutting Lathe Model CS   Advertisements 1930
GA 21/2" Precision Plain Lathe   Portass-built Mk. 5 Lathe Photo Essay
George Adams Ehrlich Lathe
Fast-and-loose countershaft unit with a foot-operated, spring-return striker fork
Heavy-duty ball-bearing countershaft with fast-and-loose flat belt drive.
The thin knurled rings at each side of the micrometer dials show that this engraving is of a very early compound-slide assembly for the WL and V1 lathes.
The heavier Compound Slide Rest for the AAA lathe.
Vertical slide to carry high-speed spindles for mounting milling cutters, drills or grinding wheels.
An unusual accessory - an alternative bed with a gap.
Cutter Frame for toolpost mounting.
High-speed Grinding Head.
Single-roller Filing Rest
Double-roller Filing Rest
Saw Table for fitting into the handrest socket
Lever-action tailstock for WL and V1  Geneva-style lathes
Additional tailstock "Runners" (what would be called 'barrels', or 'spindles', on a larger lathe) with various kinds of useful end fittings were available to fit the plain tailstock which was supplied with a simple runner having a male centre at one end and a female at the other.
Plain Tailstock with a 'male and female-centres' runner.
Lever-action tailstock for the Wl & V1 Lathes. This unit had a tapered socket in the end to accept small drill chucks and other items with tapered shanks.
Lever-action tailstock fittings with tapered shanks:
top row - Pin Cutters
bottom row - Flat Countersinks.
Both were sold in sets of 20.
Universal Runner. This was sold in a set with the eccentric holder, one plate with 20 different counter-sunk holes, another with 8 hollow centres, a centring pin, two small drill holders and one small drill pad.
George Adams Home Page   GA Lathe Model 21/2"
GA 21/2" Precision Plain Lathe   Watchmakers' Lathes
Portass-built Mk. 5 Lathe Photo Essay George Adams Ehrlich Lathe
