E-Mail Tony@lathes.co.uk
Bradford Metalmaster Lathes
1953 Metalmaster
1941 Metalmaster
14-inch Stud Lathes   16 & 18-inch Lathes   21, 25 & 28-inch Lathes   30, 32, 36 & 42-inch Lathes
Carriage & Slides   Accessories   Factory   Headstock, Bearings & Friction Backgear
Bradford Home Page   1950s Metalmaster Lathe   1941 Metalmaster
     Coarse Screwcutting Attachment
The popular, inexpensive and well-built Metalmaster lathe was built in 12, 14 and 16-inch swing versions - with actual swings of 141/2, 161/2 and 181/2 inches respectively. The "Metalmaster" was built in at least two types - an early version of the 1930s and early 1940s, and a later machine, probably introduced in the late 1940s.
The date of production can usually be found cast into the underside of the headstock cover.
Can any reader help with a picture of the screwcutting plate from the gearbox of a Metalmaster  of any year? If you
The Metalmaster as produced in 1953. This version appears to have been current from the late 1940s
E-MAIL   tony@lathes.co.uk
Bradford
1953 Metalmaster
1941 Metalmaster
