Atlas 9-inch & "Metalmaster" Lathe
- continued -
Back to Atlas 9-inch & Metalmaster Page
A complete data pack is available for the Atlas 9-inch and other Lathes
Atlas Home Page   Atlas 6-inch    Atlas 9-inch   Late-model Atlas 12-inch   Atlas Utility Lathes
Restored 10-D & 10F   Acorn, Halifax & Sphere Copies   Early 9-inch Metalmaster Lathes
Atlas Screw-Machine (capstan)    Screwcutting Gearbox and Pick-O-Matic Threading
Atlas Factory   Catalogue Covers   Accessories   Atlas Wood Lathes
Countershafts   Atlas Miller   Atlas Shaper   Atlas Drill Presses
A thread-dial indicator appears to have been fitted as part of the regular equipment
Threading chart as fitted to the Atlas version of the 9-inch
Badge and threading chart as fitted to the "Metalcraft" version, a model mechanically identical to the standard Atlas-badged type.
The equivalent Craftsman model was the Metalmaster 9" x 18" 6 speed centre lathe with its revolutionary Collins all-V-belt integral countershaft system. In its basic form the lathe lacked both an electric motor and a compound slide rest (that was a additional $13 to the $64.50 cost of the basic lathe) - but it did have a full set of screwcutting changewheels, faceplate, drive dog, a (very cheap) household-grade electrical switch, a dial-thread indicator, two cutting tools and a motor pulley.
If the badges have disappeared from a lathe, the manufacturer's version, the Atlas 9", can always be identified by its different bed feet which, instead of the open cast boxes shown above, flared outwards in a smooth curve. Oddly, the Atlas patent drawing showed the bed feet as used on the
Metalmaster..
Atlas 9-inch & "Metalcraft" Lathe
- continued -
