Raglan Mk2. Little John test-piece turning lathe. The backgear-engagement lever slot was blanked off and, out of sight on the back of the bed, was a form of taper-turning attachment - more accurately described as a forming attachment - to which could be fixed a template of the form required to be turned.
A raglan Mk.2 Little John set us as a brass-finishing model. Almost certainly, by the 1950s, not a hot-selling version
An early but well-specified Little John capstan lathe mounted on the heavy stand with coolant, bar-feed, a full-length splash back and power-feed to the turret
Although its seems that many sellers on eBay are fixated on showing the back rather than the front of their lathe, it was unusual for makers to do so - and this picture has yet to be found in any Raglan sales literature..
Variable-speed drive arrangement used on the standard backgeared and screwcutting Mk.2 Raglan Little John
Variable-speed drive arrangement used on the capstan version of Mk.2 Raglan Little John
Judging by their appearance (and the fact that no known lathe has survived with them, the Transfers on the changewheel cover must have been applied for the publicity photograph
Beautifully prepared for its publicity shot - the changewheel drive of a Mk.2 Raglan Little John
Coolant system built into the back of the early very heavy stand with cast-iron base and chip tray
Simple, strong and versatile, the Raglan wood-turning lathe advertised as "The Little John Woodturner" and fitted, in this case, with the optional rack-driven carriage.
