Repairing a Broken Headstock Casting
A copy of the very rare catalogue for this lathe is available.
Myford 4-inch Precision Home Page   Myford Home Page
Cheap and simple to manufacture, the "split-on-one-side" type of small-lathe headstock bearing was widely used on a number of small British and American lathes during the 20th century. Kept well lubricated, they were surprisingly reliable - the danger coming from removing the wooden or red-fibre strip from between the two halves and over-tightening resulting in a cracked casting.
Welding usually proves unsuccessful for, even pre-heated in a muffle furnace, welded with the right rod and allowed to cool down very slowly, distortion of the whole casting results. Machining the glass-hard weld is also a problem…
The only sensible solutions are to either find another lathe of the same type and use it for spares - or machine off the casting level with the lower face of the split and make up a bolt-on  big-end type con-rod cap. The photographs below, contributed by a reader, make the process clear.
Broken headstock bearing
Casting machined off level with base of original split
Both bearings machined off and casting drill and tapped to take the holding studs
Bearing block and hand-shaped finished piece
Finished bearing cap
Testing for fit
Testing for fit
New bearing shells were made from Tufnell (though bronze would have been just as good)
Both bearings replaced
