 Continued: Mitsui 5A Jig Borer of the late 1950s and 1960s Workhorse of the Mitsui range was the No.5, a hydraulically-driven, double-column "planer type" jig borer with the table sliding longitudinally on a massive base casting. The head, held on a saddle, was able to be traversed from side to side on a beam that connected the two columns and raised and lowered through a range of 23.5 inches - all movements being by both hand and under power. These scales were claimed to be of exceptional accuracy and ruled on the Mitsui's own very highest precision dividing machines. They were inspected with reference to the most precise of the line standards of the N.P.L. (National Physical Laboratory of Great Britain) and designed to have as close an expansion coefficient to that of the machine body as possible. Optical readers were fitted to the right-hand side of the bed and on the cross beam, each being provided with a projection screen that magnified the divisions on what was called the "standard scale" by a factor of 25. On the screen was a forked slit, the position of which, for vernier readings, could be adjusted by a "micro drum". In use, the operator would first set the table or spindle head to an accuracy of 0.05 inches using the ruler scales, this positioning a division line of the standard scale on the viewing screen. The line was then further adjusted, using the micro drum, to the third, fourth and fifth decimal divisions of the required setting. The table, or spindle head, was then moved using the appropriate fine-setting knob until the standard scale division line was aligned between the fork slit - the vernier setting of the latter reading to 0.00005 of an inch. In use, operators of optical systems say that they were surprisingly quick and easy to operate and, once used to the inevitable "black art" compromises needed, highly accurate. Optical readers were fitted to the right-hand side of the bed and on the cross-beam, each being provided with a projection screen that magnified the divisions on what was called the "standard scale" by a factor of 25. On the screen was a forked slit, the position of which, for vernier readings, could be adjusted by a micro drum. In use, the operator would first set the table or spindle head to an accuracy of 0.05 inches using the ruler scales, this positioning a division line of the standard scale on the viewing screen. The line was then further adjusted, using the micro drum, to the third, fourth and fifth decimal divisions of the required setting. The table, or spindle head, was then moved using the appropriate fine-setting knob until the standard scale division line was aligned between the fork slit - the vernier setting of the latter reading to 0.00005 of an inch. In use, operators of optical systems say that they were surprisingly quick and easy to operate and, once used to the inevitable "black art" compromises needed, highly accurate. Carried on a very heavy and rigid box-type base, movements of the 5A's head in any direction were claimed to have only a slight effect upon the centre of gravity. In addition (as was normal with this type of jog borer) the table could not be moved to overhang the ends of its ways - both features adding to the theoretical rigidity and consequent accuracy. Driven by a 2-speed, 3 h.p./4 h.p. motor, the 8-inch-travel spindle had eighteen speeds that spanned 40 to 2000 r.p.m., the power down-feed rates being 0.0008, 0.0014, 0.0024, 0.005, 0.007 and 0.012 inches per spindle revolution. To allow tapping to be carried out - at speeds below 120 r.p.m. only -  the spindle direction could be instantly reversed, an automatic stop being fitted that worked at rates of feed and speeds. The stated drilling capacity was 2.375" and boring 10", both through cast iron. Fine and quick-action hand control of the spindle was also provided as standard by, respectively, a handwheel and lever. Handily, automatic tool clamping and unclamping from a No.4 Morse taper socket was also fitted, electrical push-buttons controlling a motor that moved the spindle drawbar.  Carrying the spindle head on the cross-beam was a saddle, this having 20 inches of travel with the drive coming from a 2-speed, 2.3 h.p./2.5 h.p. motor working through a ball-screw and reduction gearbox. Two rates of feed were available when used for milling at 2 and 4 inches per minute, together with a rapid setting of 47.25 inches per minute. Driven hydraulically - for smoothness on changes of speed - and with a single lever to start, stop and reverse it, the table had a working surface of 33.5" x 26", a longitudinal travel of 29.5 inches and a range of infinitely variable, stepless feeds from 0 to 80 inches per minute. A separate, floor-mound hydraulic accumulator and storage tank was supplied, the pump being manufactured by Mitsui and arranged to automatically change its output according to differences between the cutting and positioning feeds. This arrangement was aimed at minimising heat-build up and ensure that as little as possible was transferred to the body of the machine. Also located separately and provided with the usual settling and baffling arrangements, the coolant tank was fitted with a pump driven by a 1/20 h.p. motor.  A wide range of accessories was listed by the maker, including a very complete, boxed, locating microscope set that included a drill chuck, centre point, proving bar, a locating attachment with dial indicator, an axial indicator, reference square, a screen illuminating device and a reduction sleeve from 4 Morse to 1 Morse with a clamping tool. Also available were sets of boring bars, twist drills, end-mill reamers, face-milling cutters, shell-end cutters, universal boring and facing heads, sets of collets and circular dividing and tilting rotary tables. A Mitsui 5A jig borer required a floor space of 106" x 78" stood 110" high and weighed around 13,200 lbs (5987 kg)..
