Mikron Catalogues and Manuals are available - Click for details
In full working order, this fine example of Mikron engineering is mounted on the maker's heavy and stable cast-iron stand No. 93. Unusually, all the horizontal and vertical milling accessories are present and this particular example has survived with the maker's slideway scraping marks intact, minimal play in the slideway feed screws and nuts - and has obviously had a very easy life.
The headstock used on the horizontal set-up is the No. 95 with built-in overarm while the vertical arrangement uses the rare, internally epicyclic-gear No. 95a, together with the indexing plate normally found on the No. 99 - the arrangement giving 12 speeds with a single-speed electric motor or 24 with a 2-speed type. The No. 98 automatic table feed is present as is the inclusion of a removable suds tank inside the base.
