Is this original? It looks to be a later bolt-on addition and uses a power shaft mounted to the rear of the bed. This not uncommon practice of the 1800s allowed (together with a second set of changewheels across the tailstock end of the bed) power cross feed to be fitted together with an extreme ratio reduction between spindle and front leadscrew for the development of very fine screw pitches or rates of carriage feed.
