Austin Type AE Chummy 1929 - 1930
More Austin Seven Material Here
The last Austin Seven Chummy with a short bonnet and long scuttle, the Model AE was manufactured from September 1929 until around August 1930.
Although it closely resembled the preceding AD Chummy, introduced in March 1926, its body was wider and more fully developed, most noticeably from behind, where it sat much further over the wings than on an AD. Although it's impossible to confirm these figures, some reports say the AE body might have been about 2½ inches wider across the doors and 2 inches longer, making it more accommodating.
If the body did not immediately give the game away as a new model, the wings did, with the Work's Index Cards recording a quite different wing design from car No. A9-9265 in September 1929. The long-established blade-type D wings were replaced by a rounder, domed style, listed as Types E and F. The shorter Type E attached to running boards that had an upward-curving front section, while the longer Type F was paired with shorter, flat running boards. The rear wings were also revised, becoming wider and deeper, and designated Type F. The wings also help distinguish early from later AE models for the Work's Index Cards record new wings from car No. B-6230 in January 1930, when a distinctive beading was introduced around their edges, the revised wings being designated Type G at the front and Type H at the rear.
Other distinguishing features included chrome in place of nickel plating on the bright fittings--although some of the earliest examples have been found with nickel--a slight, almost imperceptible increase in bonnet height, and a splinter-proof Triplex windscreen.
Mechanical changes at around the time of the AE's introduction, included in October 1929 from chassis No. 97,489, a stiffer crankshaft was introduced with its journal diameter increased from 1⅛ inches to 1⁵⁄₁₆ inches, and the rear main bearing housing increased in size so that the crank could be threaded through it. A ball-change gearbox replacing the original gate type and a lighter, lower starter motor with the Bendix pinion of its output shaft fitted. According to the surviving changes-of-specification Index Cards, the new starter, complete with a floor-mounted switch, was introduced on October 29th, 1929, at chassis No. 99,001. By November of 1929, the change was also shown in parts list, edition 670b. The new starter also solved a long-standing problem; the previous tall 'bacon-slicer' type left little room for the driver's left foot, which could also, with greatest ease, accidentally press the built-in starter switch.
How many AEs were built? It's very difficult to say, as by the time the AE was introduced, saloons were heavily outselling Tourers, and chassis-number listings do not distinguish between the types. The writing was on the wall as early as 1928 when it's believed that the works produced 8233 Tourers, and 6,473 metal and fabric Saloons; in 1929, 5,304 Tourers and 11916 metal and fabric Saloons; in 1930, 3,187 Tourers and 16,221 fabric and metal Saloons and, in 1931, just 1647 Tourers but 18,510 ordinary, De Lux and fabric Saloons (the latter type by then completely out of favour with just 782 sold.
The A7CA register downloaded on the 7th of November 2026 lists 192 "AE Tourers", but only 11 have recorded body numbers, and identifying these cars as AE themselves needs cautious treatment.
One final mystery: coupled brakes were introduced in the summer of 1930, but was AE ever fitted with them? It's probably impossible to say, as some uncoupled-brake AEs are known to have been converted by their owners, so muddying the water.
The AE was superseded in 1930 by the even roomier AF, still with an aluminium body and then, in 1932, by the steel-bodied AG.
A contemporary photograph of a 1930 AE, which, judging by its condition and unworn tyres, must have been nearly new. This example is fitted with a seldom-found accessory, a horn ring around the steering wheel
AE dashboard: speedometer, switch panel with ammeter, oil pressure button and a patent plate
Austin Type AE Chummy 1929-1930
