The name "Ricardo" in respect of cylinder heads has become a generic one for those that incorporate "squish", a flat region of the head very close to the piston that generates high-speed turbulence in the mixture, improving mixing and promoting more complete combustion. This arrangement, patented in July 1920 (Patent GB148046A) provides more power, but at the expense of increased engine stress and a pronounced rumble if the ignition timing is too far advanced. The standard Austin Seven cylinder head used until 1936 had no squish band, and its 18 mm spark plugs were mounted over the cylinder's centre line. The early compression ratio was very low, around 4.5:1 and this almost certainly helped protect the fragile two-bearing "bend-wire" crankshaft with 1.125" journals. It also made the engine relatively resistant to plug oiling. As an additional bonus, in times of hardship, it allowed the car to warm up on petrol and then switch to paraffin (kerosene in the USA) as many did in the UK during the fuel-rationing period during WW2, and for some years afterwards.... The cylinder head of the "Ricardo" pattern, fitted to the Ruby from 1936 onwards and with 14 mm plugs over the valves, has a reputation for causing plug oiling when fitted to a worn engine. However, many of the other copies, listed below, do not exhibit this fault. The head fitted to the American Austin is also of the Ricardo type, and delivers a similar increase in performance. This head design was also used earlier, with 18 mm plugs, from the early 1920s onwards, on a variety of sporting and racing Sevens. Here is a selection of early low-compression heads with varying compression ratios. At the risk of wandering too far off the answer, Austin Seven cylinder heads have long been a topic of conversation and controversy, and many third-party suppliers have attempted to improve them. While most of these were made in aluminium, some, as replicas of those fitted to sporting and racing Sevens and marked "9E", have been made correctly in cast iron. All have featured, to varying degrees, a design based on the Ricardo. A current example of the 9E, produced by Dave Dye, has an excellent reputation. Older and lesser-known, but better-known makers include: The original Ricardo (manufactured, it's believed, by or on behalf of Thompson & Taylor of Brooklands) Whatmough-Hewitt, known for its smooth power delivery and sometimes carrying a plate engraved "Whatmough-Fishere Patents No. 279,526,303,29 5 and 'patents pending'. Automotive Engineering Co. Ltd., Twickenham. Middlesex, primary licensees for Whatmough's heads The Aluminium Cylinder Head Co Ltd. Cambridge Engineering Dante Engineering Co. of Luton (sold from 1956 through Robin Reads' Sporting Motorist Agency) Alta (recognisable by its inclined plugs) Speedex Supaloy Laystall (possibly not a proper Ricardo design) Phoenix Arnott Specialloid and LRM (the last two possibly connected), and occasionally, ones do surface with no maker's name. In the 1920s, extracting more power from the side-valve engine became something of a contest between Sir Harry Ricardo and Wilfred Ambrose Whatmough. Ricardo championed turbulence--generated by squish--as the key to improved combustion and power. Whatmough, a physical chemist, took the opposite view, favouring thermodynamics and control of the mixture flow. The "Whatmough-Fisher Patent" plates seen on some aluminium heads refer to Whatmough's collaboration with carburettor specialist Fisher, centered on what they termed "Total Mixture Preparation." They aimed to achieve complete vaporisation and deliver the charge into the cylinder without "puddling" in the manifold or head, thereby reducing or eliminating the need for violent turbulence. To support this, the first Whatmough head (the incorrectly stamped Patent 279,526) introduced a "gradual relief" design. Rejecting the sharp edges of Ricardo heads--which Whatmough believed encouraged fuel stagnation--it used carefully contoured surfaces around the valves to maintain a smooth, high-velocity, well-atomised stream. The result was improved tractability: smoother pulling at low speeds and better hill-climbing in higher gears, along with reduced pinking and mechanical harshness. In short, while Ricardo's squish heads became synonymous with outright performance, the Whatmough-Fisher approach offered a more refined alternative, prioritising smoothness and flexibility over turbulence-driven power. Whatmough's patent also suggested that, rather than placing the spark plug over the intake valve or at the centre of the cylinder, as was then common, it was better to place it near the exhaust valve. The theory must have been that by starting the flame at the hottest point in the chamber, the burning gases would travel toward the cooler regions of the cylinder; if the spark had started at a cooler point, as the flame front progressed towards the hotter regions, the gas in those regions would be ignited prematurely and so cause pinking and knocking. A second aspect of the design focused on thermal management, as detailed in a British patent which, when decoded, showed that Whatmough viewed the combustion space as a chemical laboratory where hotspots were the enemy of high compression ratios. To combat this, he created "differential cooling," in which water passages directed more cooling water over the exhaust valve seats and the chamber's furthest reaches. With high compression ratios, this design attempted to eliminate the then-common pre-combustion pinking that often plagued other high-performance heads of the day. James Fisher was a noted carburettor specialist, the name on the patent often appearing as 'Fishere' (which might have been a bit of period branding flourish), though legal records list him as James Fisher. Together, the two men worked to prepare the mixture fully up to the point of ignition. Fisher's job was to ensure the carburettor atomised the fuel as perfectly as possible before it reached the manifold, while Whatmough's job was to keep it in that gaseous state until ignition. The plates attached to some of the Whatmough heads have confused people using patent database searches such as Google and Espacenet, and finding the original documents for Whatmough-Hewitt and Whatmough-Fisher can be difficult. Because Whatmough was a professional physical chemist, his designs were often seen as more "intellectual" than Ricardo's. Because brass often carries many patent numbers, he may have tried to protect chemical and thermodynamic theories as well as the combustion chamber's physical shape. The plates also often have minor typos or listed application numbers that were slightly modified upon final publication. In addition, 1920s British patents were indexed using a less-than-perfect Optical Character Recognition system of that era, which caused them to differ by a few digits in modern databases. As a result, a conventional search will often come up empty. For convenience, the British and American patents for Ricardo and Whatmough are reproduced below. Some other interesting links with comments and reports: https://pub25.bravenet.com/forum/static/show.php?cmd=show&frmid=5&msgid=1008050&usernum=2099944454&utm
https://pub25.bravenet.com/forum/static/show.php?cmd=show&frmid=5&msgid=919428&usernum=2099944454&utm
https://pub25.bravenet.com/forum/static/show.php?cmd=show&frmid=5&msgid=973196&usernum=2099944454&utm
