TOS FB-25 and FB-32 Milling Machines
Manuals are available for the TOS FB32 and FB-25
FB-25 Continued on Page 2   FB-32 on Page 3
TOS Millers Home Page
Manufactured during the 1960s into the early 1970s, the FB25 and FB32 were heavy-duty, professional machines intended for production and one-off work. Able to mount jobs up to 350 kg in weight and weighing just under 3 metric tons the FB25 was build as horizontal, universal (horizontal with a table swinging 45° each side of central) and vertical models. All shared the same basic main column, motor-drive system, 5.5 kW (7.3 h.p.) motor, 1250 x 350 mm table and identical 24 rates of table feed - these being from 8 to 1600 mm per minute longitudinally and in traverse and 3.15 to 630 mm per minute vertically. All versions had 18 spindle speeds, those of the horizontal models being set at 35 to 1800 r.p.m. and the vertical from 45 to 2240 r.p.m.
The full specification of the FB-25 can be found on page 2 and the FB-32 on page 3
TOS FB25 and FB32 Milling Machines
