South Bend 10-inch "Junior" Lathe
South Bend 1941 Catalog Complete
South Bend Catalogs Complete Editions 1918 to 1967
South Bend Lathes pre-1920  South Bend Lathes 1920-30
South Bend Model 5 - Earliest of the 9-inch "Workshop" Lathes
First Ever Model 5 Catalog - the original "mention" of the 9-inch
South Bend 9-inch "Workshop" Lathe  South Bend 9-inch Catalogs
South Bend Lathe Accessories
8-inch & 9-inch Junior & Model R   8-inch and 9-inch Junior Lathes Photographic Essays
Historic, very early 1910 South Bend 10-inch  Series 20 Toolroom Lathe - Superbly Restored
South Bend Heavy Ten - an overview   South Bend Heavy 10 from 1961 and 1991 Models
South Bend Heavy Ten Specification Catalogs   South Bend 10-K Light Ten
South Bend G-26-T   South Bend Silent-chain Drive Lathes
South Bend Lifted-Centre-Height Lathes
Copies and Clones of South Bend Lathes:
Boxford, Ace, Blomqvist, Smart & Brown, Purcell, Sheraton, Hercus, Sanches Blanes
Special Factory Production Machines   South Bend Factory   Making the South Bend
South Bend Users' Group   How old is my South Bend Lathe? The Rarest South Bend Lathe
South Bend Shapers    Rebuilding a 1952 South Bend 13-inch (large PDF)
The rare "Junior version of the South Bend Heavy 10 with changewheels for screwcutting and a plain, non-power feed apron.
New for the 1937 season was the "Pedestal" drive unit - a substantial cast iron affair which was hinged to a floor plate.
Not only were twin turnbuckles used to ensure that the countershaft could be given the right "set" (so that the flat belt ran in the middle of the pulleys) but the over-centre arrangement, by which the belt was tensioned into its working position, also carried heavily-built twin cams which pushed evenly against each side of the upright.
This unit would have made an ideal drive system for a lathe removed from a line-shaft workshop and set up as an independent machine.
Another view of this countershaft can be seen HERE.
