Belts   Books   Accessories
Myford Saw Table Assembly
- as used on the ML7 and Super 7 Lathes -
Listed under  Accessory Number 1407, the Myford saw table was included the first ever fully illustrated 7-Series catalogue dated October, 1947 and remained listed until the late 1980s.
Apart from the nuts and bolts - which should be the usual fully-machined, chemically blacked Myford type - the unit below is in its original factory finish. With a 64 square inch table, The unit was mounted on the cross slide using T-blots with the saw blade carried on a arbor held between centres.
