Books   Accessories
Lathe Parts - Tumble Reverse
Parts Home Page
Screwcutting    Countershafts    Backgear    The Watchmaker's Lathe
Tumble Reverse   Quick-change Toolholders   Fitting a Chuck
Spindle Nose Fittings    More Names of Parts   Epicyclic Backgears
Stuck Chuck   Countershafts, Jackshafts & Spindle Speeds   Oiling
   Reading Microscopes, Bevel Protractors, Combination Squares
and using Calipers & Dividers, etc.
Be sure to click the hyperlinks above for a complete picture
of how a lathe and associated equipment functions
An English Boxford VSL lathe showing the typical but clever lever-operated "tumble-reverse" mechanism fitted to many lathes. By this means the direction of drive to the leadscrew (and power-shaft if fitted) can be reversed and the carriage caused to move either towards or away from the headstock.
In its neutral, central position it allows the headstock spindle to revolve without driving any of the gears. Moving the
engagement lever up or down (the spindle must be stationary of course) engages one or other of a pair of tumble gears below the spindle gear causing the next gear in the train to revolve either clockwise or anticlockwise. The lever is usually, but not always, spring loaded in some way, with a plunger that engages in one of three holes in either the front or side face of the headstock.
On all types, the
stud gear is made removable, allowing it to be part of the screwcutting train or set up, as very small gear, to give a fine feed to the carriage
See below for other examples of tumble-reverse units.
The same type of tumble-reverse mechanism on an American "Craftsman" lathe.
Another "Craftsman" lathe - but this time the tumble-reverse operating lever has to be unbolted before it can be moved.
Kerry changewheels. As shown, the final drive gear from the tumble reverse mechanism is not fitted
Parts Home Page
Lathe Parts Tumble Reverse
Books   Accessories
