E-Mail   Tony@lathes.co.uk
Holbrook 4-inch Model B No. 8 and Type C8
Electronic Toolroom Lathes - page 2
Holbrook Model B Home Page   Holbrook C8 Photographs
Instruction & Maintenance Manuals are available for a range of Holbrook lathes
Holbrook Model B No. 8 & C8 Electronic Home Page   Main Holbrook Home Page
   Holbrook Serial Numbers
Bullwheel to pulley engagement pin. Not the circle of indexing holes
Lever to set coarse point for automatic disengagement of carriage feed
Micrometer dial to set fine adjustment of carriage feed disengagement
Gear used to move third-rod carriage disengagement function
The depth of engagement of each gear on the tumbler could be adjusted by stop screws
The top lever was used to engage and disengage the drive to the screwcutting and feeds gearbox
Taper-turning unit - to help set the required angle, a screw adjuster was provided
Holbrook Home Page   Holbrook Serial Numbers
and Type C8 Electronic
Toolroom Lathes
