Churchill Precision Grinding Machines - of the older type -
Manuals are available for many Churchill Machine Tools
The following listings are from a full-range catalogue published
during the late 1940s and early 1950s that shows machine
types current from around 1940 to 1960 and later.
Plain Grinders AW 6-inch swing BW 10-inch swing CW 12 and 16-inch swing BW & CW Angle-head types D 18-inch swing DE 26-inch swing F 24-inch swing FA 30-inch swing FB 36-inch swing Universal Grinders OH 8-inch x 16-inch OH 8-inch x 16-inch Tool & Cutter PAW 10 and 24-inch PBH 12 and 16-inch swing PCH 24-inch swing Internal HBY Plain HCY Plain HDY Plain HBA Automatic (Plunge Cut) AC and UAC Universal No. 1 Cylinder No. 2A Cylinder No. 3 Cylinder No. 4 and 4A Cylinder DUA Duplex Cylinder HF Long Bore FH Long Bore BD Brake Drum Other Churchill Grinders BW Cam TG Thread VB Slideway VBA Double-head Slideway SHC Spline Shaft SHB Broach Sharpening EC Centreless
Railway AJB Axle Journal AJW Axle Journal DAJ Axle Journal DAX Axle Journal LQ Locomotive Crank Pin LCP Locomotive Horn Cheek UH Double-spindle Hole UHR Universal Radius Link & Hole UR Radius Link and Hole PUA Cylinder, Surface and Link DE Piston Rod, 30-inch swing CE Piston Rod, 26-inch swing Crankshaft DCH High-production Type DCY High-production Type CRM Re-Grinding D/E Medium Duty F Heavy
Roll C 14-inch swing D 20-inch swing F 28-inch swing TWA Traversing Wheelhead TWB Traversing Wheelhead TWR Traversing Wheelhead Surface NB Horizontal Spindle OSB Horizontal Spindle OSG Horizontal Spindle OSV Vertical Spindle VXA Vertical Spindle VL Vertical Spindle VH Plano VHM Plane NH Plano RA Rotary Table RBY Rotary Table RD Rotary Table
