Boxford Gap-bed Lathe
beltsthread-dial indicators and faceplates
We also supply changewheels and other spares including
An example built by the parent Company Denford Small Tools (D.S.T.) and discovered in South Africa during 2013, this most unusual Boxford had an entirely different bed to the normal models - much longer than standard and fitted with a detachable gap. Using otherwise standard parts - headstock, carriage assembly, screwcutting gearbox and tailstock, it was a relatively early Model A from around 1950 and preceded the equivalent South Bend 9-inch version by 10 years, that model being introduced circa 1960 (the Boxford being based, of course, on the original South Bend "9-inch").
Possibly an experimental machine taken to South Africa by an ex-employee, it was bought by its present owner from a gentleman who had discovered it amongst a warehouse full of tools sold to him by a person moving back to England. However, it is also likely - bearing in mind that it has a Denford inspection stamp in the bed - to have been one of a batch built to an importer's or Government agency specification; however, it's almost certain that it's origins will remain a mystery forever.
Should any reader have further information, or example of the same lathe, the writer would be interested to hear from you..
Boxford Model A long-bed, gap-bed lathe circa 1950
South Bend 9-inch gap-bed circa 1960
Gap-bed Model A Boxford during restoration
Bed with gap piece out
Gap piece removed
Serial number and Denford inspection stamp
Gap piece bolted in place
Complete on its maker's stand and as discovered
A detailed Manual & Parts List  is available for all Boxford lathes.
