Atlas & Craftsman Drill Presses (Bench & Pillar Drills)
1937-1938
Atlas Drills 1931/32   Atlas Drills 1933/36   Atlas Drills 1939   Atlas Drills 1940s   Atlas Drills 1950s
Manuals for Atlas machine tools can be found here
Atlas Machine Tools Home Page
By 1937 the range of Atlas drills and their accessories had reached its most comprehensive. While the original, low-cost plain and simpler ball-bearings models remained in production, a new model, the improved Model 52 for bench mounting - together with an equivalent floor model, the 72 - was introduced. These two drills had their table surfaces ground finished, were equipped with a more rugged head casting - braced  where it wrapped around a heavier column - together with a front 4-step V-pulley running in what was described as a new design of double-row ball race that could better resist the effects of belt pull.
Pictures below are high resolution and take time to load
1937-1938
