email: tony@lathes.co.uk Machine Tool Manuals Catalogues Belts Books Accessories lathes.co.uk Arboga Drilling Machines A3008, E135, A4008M, AR4008L, A4008U(M) & A135 Arboga Instruction Books Arboga Milling Machines Still in business, the Swedish Arboga company make a range of bench, pillar and radial-arm models. The design has long been unusual in that all models, even the lightest, eschew the usual 'motor-at-the-back-with-V-belt-drive' for the exclusive use of powerful, all-geared heads. While some early models used "pick-off" gears - gears that were arranged in pairs and had to be manually and inconveniently swapped over to change the spindle speed - most had changes made by lever control. One serious disadvantage of the design was the motor, this being built into the casing and so impossible to unbolt and replace. However, the design did lend itself to the development of a range of small vertical milling and "milling/drilling" machines - these using - combined with well-made, non-elevating compound tables - heads from the standard drilling machines - details of these millers can be seen here. In the listing below, a suffix "R" stands for a radial-arm drill. Arboga Drills Models ER 830, ER 1830, E 135, E 830 & EST 830 Arboga Drills Models 2508, 2512, GSM 5012, GM 5012 & GSMK 5012 Arboga Drills Models 3512 Types GM, G2M, G3M, G4M, RLM & RM Arboga Drills Models RLM 3508, RM 3508, ER 125, ER125S, ER825, A2508 & A3008 Arboga Drills A3008, E135, A4008M, AR4008L, A4008U(M) & A135 Arboga Drills Models E100 & ER100 Series, E824 and "Full-Range" Listing Arboga Drills "Drill Accessories" & Bench Drills Models E108 and E830 Arboga Double-ended Grinders Models 308 & 312 and Drill E830 |
